Quote: Just to clarify... The white plastic switch mounts on the backside of the metal dash frame with two screws... NOT on the outside between the metal frame and plastic bezel. Yes from behind, but I don't know how many screws hold it, can't see.
The bezel mounts to the plastic using two more screws. Yes
Where does the solenoid go? Close to ashtray, again can't see up there very well. I would think a FSM would show it
