The pic posted by JMCFAN is correct of what the mounting hole should look like. The switch mounts directly to the metal frame. The 2 holes on the plastic dash cover are just for the plastic "air Grabber" bezel. If you don't have a map light your car will have a metal block off plate. I may have an extra.
