Quote: Jeff the Cuda skins had issues with the center body line fading away over the wheelwell. Sometimes as much as two feet of bodyline are missing,depending on how much the stamp was used. I think there was also some fitment issues with the rear valence pan with the skins too. Plus the skin will require welding a seam down the entire length of the panel,instead of just around the top well. I would use the AMD full skins and cut them to fit the convertible.
