Quote: six pack will only open the outboards either too fast, to slow, or just what the engine needs (ie not fully open), depending on the spring.
thermobogs put all four blades on end when you firewall it, and the air valve open fairly fast without the dreaded "bog".. as long as a wanna be tuner never touched it.
so my vote goes to the T-bog.
YAY!
I've run both. Both will bog and both will not open fully if they are not set-up. It has nothing to do with the equipment it has to do with the operator. AND I CAN SAY that when the outboards open on a 6-pack it's WAAAAAAY more of a kick in thattail than when the 2ndaries on a TQ open. Not even close.
