Over the weekend did some work on this. I wanted to take the advantage of the E-coil and not just the HEI module. It took me three tries to get a bracket that would fit and still leave some access. I mounted the E-coil in the same location as the factory coil. I was going to re curve my distributor after the modification was done, so I didn't want to mount the HEI to it. So I made a mount on the front of the coil. I still have some wiring to complete before I test this out.
