I had to run one of them to ground to get it to charge. Any ideas how to wire it to the newer regulator?
run the blue "ign" wire to the "top" terminal of the flat reg and T off of this blue wire and run it to the alt field terminal in use. "unground" the other field terminal and run it to the "side" (right side actually) terminal only (no T) on the flat reg. The "top" and "side" positions are with the triangle facing up like a pyramid.
