I installed my new Pertronix Flame Thrower distributor with the Ignitor III and it has a bad hesitation off idle. I am thinking that it is caused by low voltage??? When the car is at idle it is showing very low voltage on the gauge and as soon as I get the rpms up the voltage goes up. It has the original voltage regulator from the poits ignition with the ballast resistor. I have this newer regulator but I am not sure how to hook it up. I tried to just disconnect it and hook up the old wires to the newer one but it wouldn't run.
1968 Roadrunner 383 auto
.060 KB 400 domed pistons, Stealth heads, Torker intake, Holley 830, Lunati Voodoo cam 276/284, .513/.533, TCI 3500, 3.91 gears, all ARP fasteners,
