However: it may push your geometry over the cliff.
Every time someone says "use lash caps" I get a headache.
i'll bite how will the rocker adjustment change the geometry on a shaft system?
A lash cap will barely do it,after that you need shims or mill the head stands to change it. to many threads down will only break the adjuster or block oil from coming out of some screws.
a simple i wasn't thinking clear is good for me
waiting.......
BB, TT5,Procharged 3300lb Street Car 4.79/154
