Quote: The old direct connection book says that the ball should be 5/16 from the rocker arm.Not all adjusters are the same.I have seen it with my own eyes that when the ball is closer to the rocker;the folcum will be closer to the shaft and will lift the valve more.Its not much but it happens.
