What?
My 69 b body which is the same car as a 70 weighs 3620 w/ better than a half tank. 440 would add only a few pounds over my 383. I have maybe 75 pounds AT THE MOST in aluminum stuff weight savings.
I also have a full spare and a jack at the 3620 weight. Power steering would add I think 46 pounds based on what others have figured on here. MA article said 90 vs. 12 so...
At that weight you should run in the high to mid
12 second zone, provided your combo is similar to
Mr. Yuck's and are running 3.91's or better!!
Good post!!
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
