I need to adjust my doors at the top front edge to be closer to the fender. The hinges have been replaced and the fenders aligned. I need to adjust the doors better before I put the hood on. I don't understand the terminology in the 73 Body Service manual. The door is in the opening good the body lines are equal but the top front of the door needs to be moved forward just a little to close the gap. But which door hinge do I loosen to get it to adjust that way. Do I loosen the one on the door or on the cowl plate? Then do I push forward on the back of the door or lift the door with a jack. Is there any good articles or instructions online about door adjustment on Mopars?
