All he needs if he's going to use a stock factory shortblock is a flexplate from a later model 360 magnum that has the weights on it, then he can run a "N" balanced converter,
When the factory changed to a weighted flexplate they also changed to a symmetric 90° converter bolt pattern, the 727 and 904 converters have one drive lug offset so the newer flexplate won't work on the 904 without elongating one hole.
With the weighted flexplate and a symmetric pattern, what stops you from mounting it in the wrong orientation??
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
