the 727 flexplate comes with 3 different bolt patterns...
11 1/8 and 10 inch...plus different bolt hole sizes...i dont see why it would not work.
check the bolt pattern on your converter...see if it is either of those two.
I'm pretty sure the larger dia of the 727 flexplate will hit the starter in the drive area. Even using the B&M 360/904 flexplate, I've had to trim the nose on some mini-starters to clear. I've also had to trim the block in the pan rail area to put a 904 behind a 360 Mag block. ![](/ubbthreads/images/graemlins/Twocents.gif)
Free advice and worth every penny... Factory trained Slinky rewinder.........
