the flexplate says it is for an externally balanced 360 1993-1999...You dont need the weights on the converter..
I believe B&M quit making the 10241,,,,,
B&M 10241 Flexplate.
Fits 1993-1999, Chrysler externally balanced 360 with A-904.
(10" bolt circle)
SFI approved flexplates from B & M are legal for use in all classes of NHRA and IHRA drag racing. They are also ideal for high performance street use or any application that may see higher than 6,000 rpm. They come with the SFI certification sticker and will not need recertification for three years
