Quote: After reading all of these posts I would like to add one overview. If you are fouling new plugs there is something wrong other than the plug brand. ....If you are fouling your plugs on a mechanically sound motor you are either using the wrong heat range or you have tune up problems. -Bob
i said that earlier in this STUPID thread. perhaps the masses will listen to you.
