it's watered down and requires more material for coverage,I've seen more than few cars done in Omni with clear completely coming off the whole car after only couple months
i have been a PPG certified painter sense PPG started there certification process, early 80's. i have never seen a PPG product deliminate if the directions are followed correctly.
i have repaired lots of jobs done at other shops where directions weren't followed and PPG has paid to repair.
the only reason for clear to delaminate is intermixing brands, spraying the base coat to dry, spraying the base coat to wet, and improper flash times.
i use omni clear almost every day for the last 15 years and it has never delaminated.
