I called up Milodon today and they said my pan might not have been cut deep enough for the seal and to send it back to summit for an exchange. I asked if it was a common issue and he said no.
I'm going to exchange it but it still doesn't explain why the seal doesn't fit correctly on my block. Mines a magnum 5.9 but it should fit the same as a LA block.
I think you need to investigate that further. Search Moparts. I know it's been discussed before. AndyF was the last person I saw that brought it up.
Next time I see Milodon, I bring it up.
