You won't have any problems with them if everything is set up correctly. It should be fine.
I haven't any issues with them at 500lbs open pressure without any bushings or honing.
Use/create Comp's recommended .030" side clearance, use a liquid assembly lube or oil (not thick paste), and whatever
you do...don't overtorque the shafts.
Rich H.
Esse Quam Videri
