Re: Should I install doors, add weight, adjust, then paint?
[Re: Challenger 1]
#689571
05/06/10 01:38 PM
05/06/10 01:38 PM
Posts: 1,128 Tulsa, OK
73cudaproject
Tulsa, OK
when painting cars with the doors closed 3M makes a foam mask to keep the over spray out of the jambs and not leave a hard tape line. http://www.bizrate.com/rd2?t=http%3A%2F%...3B2%3Bmain%3B1. it works great. if you are spraying sealer it will leave a sealer line in the jamb so be careful. they also make a special tape to stop sealer lines. if someone needs the number i will call the paint store for it.
Great info, Thanks
I agree this is great info. I have been working on my project off and on for the past several years. Last night I showed a friend the car and I pointed out to him the weld lines at the rear qtr patch panels. Since I have invested so many hours into the project he advised me to hold off on painting and try to do a little more body work to try to hid the weld lines. While I am very much looking forward to getting the car painted I think I am going to take his advice and try one more time to hide the weld lines. On each side even after using bondo there is a small ridge which can be felt by hand. I am sure it will both me for years if I paint and it sticks out like a sore thumb.
I am not much of a dolly and hammer guy; however I read to put the dolly on the back side and strike with the hammer near the dolly but not on the dolly to move the metal. I am going to give it one more try before resorting to more bondo. On second thought before I break out the hammer and dolly I might try one more skip coat of bondo and then instead of using a sanding long board I might try some type of sanding block that contours to the curve.
Again thanks for the great info which I hope to use in the very near future!
Entire Thread
73cudaproject
05/05/10 07:12 PM
Kern Dog
05/05/10 08:03 PM
Barnabas_Kriss
05/06/10 05:48 AM
dvw
05/06/10 12:40 PM
Mr T2U
05/06/10 12:55 PM
Challenger 1
05/06/10 01:05 PM
73cudaproject
05/06/10 05:38 PM
crlush
05/06/10 06:19 PM
1_WILD_RT
05/06/10 08:06 PM
1_WILD_RT
05/06/10 12:52 PM
sthemi
05/07/10 12:47 AM
73cudaproject
05/25/10 06:38 PM
4BBodies
05/25/10 07:50 PM
