the axle nut should have provisions for a cotterkey, as this secures the axle to the wheel hub.[at least the ones to 06, so i would guess the 09 is similar]. the torque is 244nm.[180 ft.lbs] with the brakes applied for this nut, as per the fsm.[in other words, real tight !] hope this helps.
