Re: Wanna hear what boost can do?
[Re: Duner]
#677040
05/02/10 06:30 PM
05/02/10 06:30 PM
Posts: 66 SRQ, FL
8valves
SRQ, FL
Yup, you've got it now.
"Optimized" in my book is properly sized turbos for the intended purpose of the vehicle, well done headers with attention paid to lengths and diameters, for both primaries and secondaries, wastegate placement, downpipe and wastegate recirculation, if any, etc.
Then we move to the cold side of things... smooth radius bends, quality intercooler cores stacked for the application, be it super cold charge or minimal pressure drop as a priority.
Then comes the head, camshaft(s). It all works together.
Do you have to do it? Not at all. Some "junk" has gone REAL fast. But if you take the time, effort, and money (HA!) you can see results above and beyond the norm. If you do it well on a high flowing head combination with the right cam you're able to see 40-50 WHP gains per PSI on sub 500" engines.
I couldn't begin to imagine the gains possible on some "big" motors!
I apologize for putting the screwy numbers originally. Another part of it is that lower boost numbers seem to do more per lb of boost than it does after you turn it up some. Once it all starts to boost stack it makes lots of back pressure against the exhaust trying to make that additional boost. At least on my junk - then return starts to drop off with additional boost.
No need for the apology, no big deal!
What you're seeing is exactly my point of an optimized setup. Sounds like it's time for you to make a jump in either turbine wheel or housing. More than likely wheel. That will have a much more significant difference than a housing AR change.
And I will say it again, keeping that 1:1 PR between intake and exhaust is crucial in making big turbo power.
Aaron M
