My combination is basically the same, except in mopar land. Its a 318 with stock small valve heads, a 467/494 Crane Cam, Air Gap and 650 DP. 3.54 gear, and 28 inch tire in a 3350 lb plus me and junk in the trunk makes it 3550 raceweight, 68 Dart. The heads are a major restriction, but on 13 lbs the car just went 11.48 @ 120 on pump gas with water/meth. Without boost, im sure it would be a mid 14 second car.
Except I built the kit, didnt buy it.
I wanted to show what could be done with a cheap motor, im willing to bet an edelbrock head swap would be worth 100 horse, easy.
We went 11.04 @ 124 with basically the same car and 318 but .512 roller, Edelbrocks w/ 8 psi boost and 575 Demon. Heads do make a diff! Later Ryan
