So far so good. I have heat cycled it a few times now. I also ran it up to 6K in all three gears. When I pulled the valve cover the nut on the glued stud still had the 30 Lbs torque I tightened it to. It is going to be interesting to see how long this holds up. Maybe someone else will benefit from this experience.
