I can`t believe you`re not using the heavy duty B&M full circle flexplate w/all of that brutal power.........there`s not much meat around those bolt holes.
What flexplate do you reccomend??That is another item I need to adress
B&M makes a full circle bad a$$ unit that`s thicker w/more meat aroud the holes..............sorry I don`t have a part # but I`m sure you can call them. I believe one`s for internal balance and the other`s external.
72 Dart 470 n/a BB stroker street car `THUMPER`...Check me out on FB Dominic Thumper for videos and lots of carb pics......760-900-3895.....
