Quote: I can`t believe you`re not using the heavy duty B&M full circle flexplate w/all of that brutal power.........there`s not much meat around those bolt holes.
What flexplate do you reccomend??That is another item I need to adress
HEMI-ITIS has no cure. My condition is fully BLOWN!!
