HI Cab The cam is already broken in and the heavier springs are still on at the moment, i've just clayed the heads again and the clearance seems ok, just need some longer puhrods and i will finish putting it together. I've also got a .625 herbert roller i might try later, just want to try the .590 first to see if it deserves it's reputation. Mick
