new O rings and also new tabs on gas tank for the locking ring are TOO WEAK, and the bend easily at the loking pressure ( BTDT on tank and new sender unit ). use the original lock ring, or over bend the new lock ring tabs
With a Charger born in Chrysler assembly plant in Valencia, Venezuela
