Re: 1.550 valv e springs, 250+seat and 700+ open?
[Re: 451Mopar]
#661267
04/05/10 01:30 PM
04/05/10 01:30 PM
Posts: 43,352 Bend,OR USA
Cab_Burge
I am using the PAC-1225 springs.
http://www.pacracing.com/1200_Series-Dual_Springs.html
OD = 1.550", 250# at 2.00", 765# at 1.20" rated for 0.800" lift.
I don't have the part number handy, but I used Crower +0.100" height Ti retainers to get 1.950" install height. I think the closed pressure at 1.950" is around 270-275. Originally I had also used +0.050" locks to get 2.00" install height, but my T&D rockers would not clear the retainer. It would probbably work if I was using lash caps, but then I would have to get shorter pushrods.
That looks like the answer I have a set of Comp Cams on there now, they set up at 275 on the seat and 670 to 680 over the nose new. This is on my 527 motor that I have been dyno testing carbs and intakes on. I lost two pistons in it due to detonation and I'm putting it back together now, the springs lost around 25 lbs on the seat and over the nose. The motor made peak HP around 6500 RPM and I'm wanting to push that higher so the quest for a better valve spring. Last question, I hope, who has the best deal on those valve springs? Thanks to all of you, together we can help each other ![](/ubbthreads/images/graemlins/bow.gif)
Entire Thread
1.550 valv e springs, 250+seat and 700+ open?Update
Cab_Burge
04/05/10 04:07 AM
rebel
04/05/10 04:27 AM
StrokerAspen
04/05/10 04:31 AM
SG duster
04/05/10 04:59 AM
451Mopar
04/05/10 05:22 AM
moparniac
04/05/10 09:31 AM
Chris'sBarracuda
04/05/10 11:27 AM
Dodgem
04/05/10 01:15 PM
moparniac
04/05/10 03:59 PM
Chris'sBarracuda
04/05/10 09:35 PM
Hemiroid
04/05/10 09:39 PM
Cab_Burge
04/06/10 07:06 PM
toplescuda
04/06/10 07:18 PM
BobR
04/06/10 08:40 PM
Cab_Burge
04/06/10 09:45 PM
Chris'sBarracuda
04/06/10 09:59 PM
CHAPPER
04/07/10 01:54 AM
BobR
04/07/10 04:32 PM
451Mopar
04/07/10 06:11 AM
572charger
04/07/10 03:57 PM
Cab_Burge
04/07/10 04:12 PM
Cab_Burge
04/05/10 05:30 PM
jim sciortino
04/05/10 07:12 PM
w2dak394
04/05/10 07:25 PM
polyspheric
04/05/10 07:35 PM
Mike Swann
04/05/10 02:35 PM
B1MAXX
04/05/10 04:01 PM
galen
04/05/10 06:07 PM
