Mine came out with a pair of common pliers. I put a 6-32 nut over the outside of the pin and just squeezed the pin in its hole with the pliers until it was flush. I did not remove it completely so I would not lose it. I put it back with the nut on the other side. I kept the rebuild kit pin as a spare.
Craig
2014 Ram 1500 Laramie, 73 Cuda
Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango
Only previous Non-Mopar: Schwinn Tornado
