If you have a donor vehicle, you don't need a 70 Coronet for the required pcs, any 69-70 B body, Plymouth or Dodge, including Charger will yeild all the pcs required, you could use a 68, but the glass runners are narrower, and the door glass rear vertical chrome is smooth in appearance, unlike the 69/70 pcs, plus the 68 stuff as far as regulators don't quite line up bolt hole wise, but would work ,....you'll need to change out the door glass as it's different between post/hardtop, any 69-70 B body, including Charger glass will fit, including vent window
IMHO the hardtop looks so much better than the post,....thumb your nose at originality, do the car the way you want,......Pssst, Black on Black would look REALLY Killer on that Bee!
![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
