0E100004 - Does your car have a rear spolier and power windows?
0E100004 M00103
Have you ever seen a cuda with no fog lamps in 1970, or no belt molding.
Thank you for sharing the Data Plate info.
0E100001 M00100
0E100002 M00101
0E100003 M00102 (car is unknown still)
0E100004 M00103
It would be nice to find 0E100003.
I have found `cudas without the road lamps and M31 belt moldings.
0E100030 has the M31 codes on the Broadcast sheet, but it is a Gran Coupe. [for reference]
0E100075 has Road Lamps (and no code) and does not have the M31 nor coded for them.
0E100082 has both, and has both codes on the Data Plate. (L34 M31)
0B100003 is the same as your car. Without. See picture. No M31 code.
0B100004 DOES have the road lamps and belt moldings, though no M31 code.
0B100010 DOES have them both.
I have many BS27x0B cars in the Registry without M31.
