Quote: For the mpg, why not the 4bt? You'll just need about 150 lb flywheel to keep your teeth from rattling out.
I still have all my teeth! Someone didn't do their homework before building their engine mounts!! But really, the 4BT vibration mostly goes away after 800 rpm. I run mine at 60 at around 1750, and it's smooth.
