I believe if its 180* out the reluctor wont line up with the pick up correctly. Is there a way to tell?
It'll be the same either way but I would drill a hole in the top of your (or a spare) dist cap between the center and #1 terminals & check rotor phasing so if it (Phasing) is off you can correct it but dropping the adv plate on the pins 180 off keeps the phasing the same in spite of the directional arrow and the 2 choices of roll pin slots on the reluctor wanting to convince you otherwise and be aware when you freeze the rotor w the light that vac adv (if used) will shift the rotor (phasing) CCW on a SB and CW on a BB and that mechanical advance does not change phasing.
