standard motor products VC184 is a 17 degree vaccuum advance module. that's the shortest vac. advance canister I've seen for the electronic ignition dizzies...
I've been looking at vac advance cans for the last little while. I can't see anything for a big block that's less than 18. The VC184 you mention has the arm the opposite way, like for a slant or SB. They actually have a 13 degree can for a SB or slant, VC173.
