Quote: when you weld up the slot, weld up the inside.
How does that work though? Wouldn't the amount of total advance the weights give not change then?
I can't find my calipers to measure the slots yet, but the slot plate says 17L on it and the vacuum advance arm has 10L on it. 20 degrees of vac advance seems like a lot?
