sorry I have been in the trans buisness 25 Plus years and I call BS on this one a quart overfilled will do nothing to a unit...
Help me understand. If overfilling will do nothing, why do people's trans vent out the TOP when they do it, and that is about 5 gallons higher then the fluid level?
Just trying to understand. And this post is about a TF-727, so leave the irrelavant stuff out. You are a professional, no?
As you can see, in a TF727, the front drum is very close to the recommended fluid level (near the case/pan line).
if you overfill it enough it will vent but 1 quart isn't that much normally to get a 727 to vent it will have to be more than 1 quart.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
