Who supplied the heads?
I'd rather not say...that WOULD be taking a jab at someone. Chalk it up to not all flow benches agree. Or some aren't even close...LOL!
Thanks Brian for that info...I appreciate it.
Really? That's not taking a shot it's reporting your findings. Which after some light work, you got numbers similar to others. I guess people should become comfortable in buying things and not getting what they pay for. You clearly didn't get what you expected from the provider, correct?
To me, it's more about finding out if your stuff is an anomoly or they have a happy bench compared to others. Look at the hughes numbers for an RHS X head with a 1.92... That's some happy numbers, 263 at .600 with a +/- 6 cfm variation. 275 at .700???
_________________________________________
Here they are straight from their site.
RHS "X" Heads
(LA & Magnum heads use the same ports)
Stock with 1.92" int and 1.60" Exhaust
Lift intake Exhaust
.100" 66
.200" 116 91
.300" 177 138
.350" 203 155
.400" 224 167
.450" 239 171
.500" 252 174
.550" 262 176
.600" 263 178
.650" 263 179
.700" 275 179
Note: These are average numbers.
Stock ports can vary by +/- 6 cfm in the same head.
_____________________________________________
