So guys, is there no way to re-set the gear ratio in the 727. Now, I'm a newbie to this type of trans talk because all I know is TF but we just run mid 10's so are TF has been very consistent. But from the way most of you guys have said, it seems as though the problems are all with first gear being to tall. Is there no way to adjust the ratios to resolve this problem?
A&A sells a 2.28 gear set. Expensive, and I don't know what power level they claim it is good for:
http://www.aandatrans.com/
1993 Daytona, 5.50 at 130mph (1/8) 1.19 sixty ft (PG). Link to 572 B1 - Part 1
