Quote: By the angle of the picture the turbos look like they are mounted extremely low. Have any more pictures?
Yeah they are low. I am going to have to pump the oil back to the pan. I am still thinking about how I am going to deal with it. I have seen setups like this before, so I know it can be done.
Its an easy fix, as Im sure you are aware of. run the biggest -an return line you can off the turbo to a y and then hit the harbor freight 39.00 pump then send it to the oil pan. rebuild kits are 5 dollars for the pump and having a few spares is affordable. Lots of 7 second guys love these dang things
