Quote: Turbo Slant 6. Not as pretty as others but very functional. All stock Shortblock (80k miles). The Head gasket is copper(o-ring'd block). The head has not been touched with the exception of some upgraded valve springs. The turbo is a PTE 6262 DBB .63ar on the exhaust. 2.76 gear,600 Holley DP., 3.5" downpipe to the axle and a 3" tailpipe. Best ET = 11.77 @ 30psi Best MPH = 117 @ 30psi Race Weight 3,500lbs
WOW that's impressive. and you are pushing 30 thru the plastic bonnet? I thought 12 was tops recommend?
