78 D-150 Adventurer 360 x headed 8:1 comp m-1 intake blow through 750 carb(home brewed) Borg Warner S475 w/1.10 exh, 4inch single exhaust..83/4 w 3.23's Best et on 8psi pump gas on BFG drag radials -11.08@125 w/2.20 60ft
This is the setup before i put it in the truck 2years ago...it has been through many changes over the last 5 years and several different turbo's and exhaust manifold setups. right now im swaping cams and putting a cage in the truck
