Sweet looking setup efisixpack,how's your car perform with it?
what size injectors are you running? I'm starting with 6, 50lb injectors.
The plates I'm using are from a holley 600 (300cfm), so 900 total my guess.I don't feel this is correct because of the the throttle bodies use straight and carbs use venturis to draw fuel, probably will flow more when I'm done machining lead in velocity stacks.
I know machining on the edge of the vice isn't good, just needed some room for the electric connectors,small details that keep things from working. All fits now.
