Looks good! Looks like you took the same approach I did when I built mine. I like the fact they look to be approximately the same height as factory carbs. It will look a lot better that way IMO. Question for ya, what size throttle blades did you go with and what CFM do you estimate?
When I die I want to go like my Grandfather did, quietly in his sleep. Not screaming like the passengers in his car.
