You make it sound easy because it probably will be. Just time consuming. I was wondering about the track width because I'm not sure how the wheels/tires would fit into the front fenders. Too far inside, too far out, etc. The Tire and wheel combo from the Dak seemed to work out good. Here's how it was then...
Just gotta imagine the '53 sitting with those wheel and tires..
When you decide to quit, THAT is the moment when you would've succeeded..
