So the power pedal has the bracket and pivot points and the manual pedal has none, is this correct? I finally called SSBC and the tech said to check if the car came with manual brakes. I checked the pedal and brake rod connects directly to the master cylinder. My 68 Charger has power brakes and there's a bracket assembly with pivot points. Since the pedal connects directly to the master cylinder on my 69 with just the rod and no brackets or pivots, I'm guessing this was originally a manual brake car, right?
