Simple - you need more line pressure. it is not difficult. Put in a master cylinder with a smaller bore and you will CREATE more line pressure with the same amount of pedal effort. The other post gave you the blueprint, get a 15/16 master cylinder so you can get on with your life. It is indeed unfortunate that an otherwise responsible company would supply the wrong size master cylinder. They probably have a bad assumption going about the pedal ratio.
