I do not have a flex plate or torque converter for the 340/727.
Will the ones from the 318/904 work? (This is a fairly mild 340 build.)
Oh, and what about the trans shifter linkages, are they the same?
The flexplate will bolt on the motor.
But the bolt pattern on the convetor might be different
The B/M flexplate is a nice fix for that. uit has both bolt patterens on it.
The convertor won't 904 and 727 use have different amount of splines on the input shafts.
Also what year 340? some were internal others were enternally balanced.
the shift linkage will work on both 904/727
also the drive shaft will nned a new yoke and to be cut down. The 727 is longer and has a different spline.
