Yes it will be leaf spings.Cal-trac and split monos.
That's what I'm running on my Gen III, sticks like glue, but I'm only running a little over 300 RWHP, hope to spray it this year, we'll see what it does with another 150 HP...
The other Dak looks like you're using a Wishbone...?
I'm all set up with Chassis Engineering shock mounts welded on the axle & relocated shocks...but still I'm using the monleafs. Since the setup works so well, I figured coil overs would be a waste for my HP level.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
