Check out the tech archives, there are many recipes for 500 hp 440s there.
I think if you build something with around a true 10:1 compression ratio, the right cam, and some Edelbrock RPM or 440Source heads, you should be there pretty easy.
I don't think doing it for a total budget for parts and machine work of $2500 is going to be real easy though.
