My guess would be at full throttle the pcv valve is closing And the crankcase is pressurizing. The other breather can't keep up. When the crankcase pressurizes it pushes oil up into the cylinders. Your best bet would be to install a vacuum pump. Gzmotorsports, Jonesracing, and Product Engineering all have Street vacuum pumps for continuous duty.
